Velocity stacks mod before dyno? - ZX6R Forum
 22Likes
post #1 of 27 Old 01-19-2017, 07:28 PM Thread Starter
WillOnTwo's Avatar
I Ride: 2013 Ninja ZX6R 636
Hi guys I'm curious if there is anybody on this forum that can shed some light here for me. The guy that's going to be my dyno guy here in the PNW has told me that I should look into putting the velocity stacks from the 09-12 bike onto my 13 636 bike before we dyno and reflash because these stacks will deliver better air flow and increase my power. This mod seems simple enough yet I cant find anybody anywhere having done a swap like this. Any advice? Anybody done it?
WillOnTwo is offline
post #2 of 27 Old 01-20-2017, 05:44 AM
Painfullyslo has done this.
post #3 of 27 Old 01-20-2017, 06:21 AM
MFChop's Avatar
I Ride: 2015 ZX6-R & 2012 GSX1300R
I have them also. I could do a comparison before and after but I wont be heading to my dyno tuner till April
You can get them off eBay very cheap. I think I paid $20 shipped
Also to elaborate more... If you are not racing DO NOT do this. This isn't a gain in overall HP but how the power is deliver you will lose lower to mid range power in order to gain upper power. The stacks merely create a shift in power
MFChop is offline
post #4 of 27 Old 01-20-2017, 10:08 AM
If I recall, the center two stacks on the '09-'12 are equal length to the outer pair.... with the '13+, the center pair has a longer flange, and possibly a slot at the base?
the '09-'12 are aimed at peak power, the staggered '13+ arrangement is meant to spread the power over a wider range of RPM. With the slightly larger motor, there was more to spread around.
post #5 of 27 Old 01-20-2017, 11:25 AM
MFChop's Avatar
INCORRECT here is a picture of my 2013 with 09+ stacks. The 09+ centers are different from the outers.
Also they completely different shapes all together
ID:	53841   Click image for larger version
ninjaman89 and Gawernator like this.
MFChop is offline
post #6 of 27 Old 01-20-2017, 11:44 AM
You have better insight than I do, LOL. I just have the '09 stacks, in my '09.
PinoyRider88 likes this.
post #7 of 27 Old 01-20-2017, 11:48 AM
ninjaman89's Avatar
So, is the thought that since a track/race bike will almost always live in the "high" RPM range, that you don't care about the lost mid range power?
The engineer in me would love to see a before and after dyno on this
ninjaman89 is online now
post #8 of 27 Old 01-20-2017, 12:08 PM
MFChop's Avatar
Exactly
Frankly Id love to see this myself. Pending if we have time after all my tuning is done I might take the time to do a comparison
MFChop is offline
post #9 of 27 Old 01-20-2017, 01:05 PM
ninjaman89's Avatar
Exactly
When are you tuning?
Also, did you confirm you have the inside/outside stacks in the correct order? I just ask because the order in your picture is the opposite of how you have them installed
post #10 of 27 Old 01-20-2017, 01:35 PM
MFChop's Avatar
Mid April
Yes mine are installed in the correct order, I actually terrified it with parts diagrams (they have the Part #s on them). Ignore the generic eBay pics
ninjaman89 likes this.
MFChop is offline
post #11 of 27 Old 01-20-2017, 02:24 PM
ninjaman89's Avatar
Mid April
Sweet!
Definitely post up your results if you do a comparison on the dyno. Its really nice to have actual data on this kind of thing. I didn't realize how cheap they were. I think I'll order some for my build as well. I'll just be tuning with an auto-tuner though.
I've been doing a little research on how velocity stacks work and have found a couple sources that say longer stacks are better for power at lower RPMs and shorter are better for higher...which makes sense since the 09+ are shorter. The only thing that weirds me out is that double-lip on them.
WillOnTwo likes this.
post #12 of 27 Old 01-20-2017, 02:33 PM
I Ride: 2014 Kawasaki ZX-6R
Sweet!
Might have to do with the 09-12 having 8 fuel injectors instead of 4. :
Martillo y Mantequilla #99
post #13 of 27 Old 01-20-2017, 02:37 PM
MFChop's Avatar
Fixed
MFChop is offline
post #14 of 27 Old 01-20-2017, 06:33 PM Thread Starter
WillOnTwo's Avatar
Exactly
I will be getting my bike tuned within the next month, If I am lucky I will try and convince my dyno guy to do a comparison dyno run. Also the other question is how easy was it for you to switch the V stacks? Just ordered V stacks my bike, essentially doing what you did.
post #15 of 27 Old 01-21-2017, 01:36 PM
scoot33's Avatar
I Ride: zx6 j2
i have a carbed zx6r ,i too was trying to find what difference there was but never found any use full info ,i cant remember which way it was but,, all short was good bottom and mid range and all long was better top end but like i said not 100%sure what way round ,i got spare ones to fit when i get spare time i know its a fi but the air flow theory is still the same
zx6r j2 mods done ,,
scoot33 is offline
636 , velocity stacks
Jumper Mod results explained bowhunter11 The ZX6R 26 04-04-2016 12:52 PM
Velocity Stacks Jcarrier The ZX6R 3 03-01-2015 02:17 PM
FS: Oem Short velocity stacks zx racer Classifieds 3 07-11-2012 01:32 PM
Factory Pro Velocity Stacks zx racer The ZX6R 14 07-26-2011 01:39 PM
Velocity stacks MV2K6R The ZX6R 0 04-08-2009 01:58 PM
