cam chain tensioner for a 04 kawi 636 - ZX6R Forum
post #1 of 25 Old 04-19-2009, 03:31 PM Thread Starter
zx racer's Avatar
I Ride: 04 ZX-636
hey guys do anybody no how to adjust the stock cam chain tensioner or where to buy a aftermarket one at, what do you guys suggest & what will work the best, bike is approaching 20k & feel the need to replace it or adjust it if i can, all help will be appreciated
zx racer is offline
post #2 of 25 Old 04-19-2009, 03:35 PM
Quarkz's Avatar
No idea how to adjust. For aftermarket I'd recommend the genuine Kawasaki one (Can get via eBay as it's now a discontinued part, I personally couldn't get it from my dealership) or the APE tensioner which you should be able to get from any accessories store or eBay. I've heard the APE have a problem not sealing properly so I was going to go with the Kawasaki one (which also looks better). They're much the same price.
Quarkz is offline
post #3 of 25 Old 04-19-2009, 06:57 PM Thread Starter
zx racer's Avatar
I Ride: 04 ZX-636
do anybody no if will take care of the famous tick or rattle that the kawi engines are known for if i go with ape manual cct
zx racer is offline
post #4 of 25 Old 04-20-2009, 04:18 AM
gammac's Avatar
I Ride: ZX6R '08
You'll need to download a manual for the procedures. Manualz.info is gone.Try Pdftown.com.
gammac
gammac is offline
post #5 of 25 Old 04-20-2009, 11:35 AM
I Ride: p7f zx6r
theres no way to adjust the ctc on your bike as its fitted with the automatic adjusting type,you can fit one from a g1/g2 model which are supposed to be stronger,also your other route is fitting an aftermarket manual adjusting one,ive done this in the past and still had the" kawa tick",one way to try and move your ctc onto its next notch is put your bike into a high gear without the engine running and push it backwards using the resistance from your engine to move the ctc on!
bucko is offline
post #6 of 25 Old 04-20-2009, 11:56 AM Thread Starter
zx racer's Avatar
I Ride: 04 ZX-636
im just going to replace it with a manual one & will be doing the installtion myself
zx racer is offline
post #7 of 25 Old 04-22-2009, 09:22 AM
kc104's Avatar
I Ride: 03 b1h
Will be interested to hear how you get on after fitting a new cct.....I'm getting a fair bit of rattle from the camchain of my B1H and was thinking of fitting a APE manual tensioner but now I'm a bit unsure which is best...standard Kawa or what? Can't see what difference fitting another standard cct would achieve as there doesn't seem to be much that can go wrong with it or do they just run out of automatic adjustment?
kc104 is offline
post #8 of 25 Old 04-22-2009, 10:00 AM
I Ride: p7f zx6r
yeh they just run out of adjustment,sometimes they stick due to being gummed up with oil,so its worthwhile taking them out for a look,the kawa ones are around £38 if i remember right,the older type from the g1/g2 bikes are supposed to have a stronger spring in them!
bucko is offline
post #9 of 25 Old 04-22-2009, 10:34 AM Thread Starter
zx racer's Avatar
I Ride: 04 ZX-636
the ape manual ones are just a upgrade for added protection to our motors to ensure we dont skip a tooth on the timing chain & could drop a valve or warp a head, im waitin on my to come in & will be installin it myself i will keep you guys posted on how it turns out, also the manual cct are alot better from what i heard its alot easier to adjust & only take seconds
zx racer is offline
post #10 of 25 Old 04-22-2009, 02:25 PM
kc104's Avatar
I Ride: 03 b1h
Interesting replies fellas. I've already had the cct out of the engine and it deffo is not gummed up and doesn't look to be on its maximun extension so maybe the spring is weak? Think I'm gonna put my money on the APE
kc104 is offline
post #11 of 25 Old 04-22-2009, 07:43 PM Thread Starter
zx racer's Avatar
I Ride: 04 ZX-636
if you change it out make sure you use the oring gasket off your old one on the new one so you have no leaks
zx racer is offline
post #12 of 25 Old 04-24-2009, 10:57 AM Thread Starter
zx racer's Avatar
I Ride: 04 ZX-636
installtion went well i even noticed better throttle responce & alittle more pep after the change & motor is back quiet again i highly recomend everybody thats experiencing a bad cct to change to the ape manual one best 50 bucks i spent on the bike in awhile and the installtion doesnt take long at all, just remove tank remove to 8mm screws & the stock cct comes right out, remove the ribber oring off the old one & install on to the new ape manual cct put it back in place where the old one came out & tighten the 2 8mm bolts back down, hand tight the adjuster tight as you can get & start motor up & adjust till all noise go away, its good to have alittle whine but if you experience rattle or ticking then you dont have it tight enough
zx racer is offline
post #13 of 25 Old 04-27-2009, 09:58 PM
d207gp's Avatar
I Ride: 2003 636, 2006 GSXR1000
I have an APE unit on order, and was going to do a self-install like I did on my GSXR. My tech sent me an email:
I have some cautionary advice on the CCT install that especially
applies to the 636 and most modern Kawasakis. More often than not - either
intake/exhaust cam will have a tendency to roll and the chain skips time
depending crank/cam positions. It’s often so subtle that you won’t hear it
skip and you’ll never know it jumped time - until you start the engine.
Always best to have valve/pulser covers off for visual confirmation of
proper cam timing.
Review section in service manual on camshaft installation to show proper
alignment of crank/cams/sprockets. Once covers are off - turn crank to #4
TDC as described in manual. Then proceed to remove/replace CCT. You’ll
likely you’ll need a new pulser cover gasket.
It can still skip time even when positioned correctly - happened last week
on that 636 I was building. While, it’s less likely on GSXRs, it can still
happen, especially on exhaust cam. That’s why I always have the covers off
to do a CCT install regardless of make/model engine.
P.
d207gp is offline
post #14 of 25 Old 05-01-2009, 08:01 AM
blkpitbull's Avatar
I Ride: 04 636 in orange
you can adjust the stock one!!
blkpitbull is offline
post #15 of 25 Old 05-01-2009, 09:26 AM
d207gp's Avatar
How so?
d207gp is offline
03 zx6r cam chain tensioner
03 zx6r cam tensioner
03 zx6r timing chain tensioner
04 zx636 cct adjustment
2003 zx6r cam chain tensioner
2003 zx6r cct adjustment
2004 kawasaki 636 cam chain tensioner
2004 zx6r cam chain tensioner
chain tensioner 2004 kawasaki zx 636
how to replace a cam chain tensioner on a 2004 zx6-r kawasaki ninja 636
replacing cam chain tensioner 2003 636
zx9r cam chain tensioner rattle
how to install a Manual Cam Chain Tensioner zx6r 07 jstunna The ZX6R 13 03-29-2016 09:23 AM
Stock Cam Chain Tensioner adjustment Kazoo6942 Mechanical and Technical 40 03-12-2012 04:16 AM
Can a 95 zx6r cam chain tensioner be used for 98-02 zx6r? idriftnaked Mechanical and Technical 0 05-20-2011 01:44 AM
manual cam chain tensioner ZoomSplat Mechanical and Technical 97 05-06-2011 06:41 AM
03-636 cam chain tensioner, can i manually adjust gaillarry The ZX6R 1 07-29-2009 08:20 PM
