High beam problem - ZX6R Forum
  • 1 Post By Strider
post #1 of 5 Old 03-28-2017, 08:17 AM Thread Starter
High beam problem
Just brought a 2016 zx6r 2nd day riding I parked it and someone tapped it with there car and it dropped thank god for the frame sliders but now when I ride I noticed the high beam keeps going on and off automatically
Midway2282 is offline
post #2 of 5 Old 03-28-2017, 09:12 AM
I presume the bike fell on the same side as the high beam bulb?
First thing I would do is make sure the bulb is still seated properly in the socket, and that the power going to it is attached properly.
Have you checked out the high beam switch to make sure it isn't damaged in some way?
If you've only had the bike a couple of days, how do you know the high beam side was working properly before the fall?
Do you have the insurance info on the person who knocked your bike down? Why are you fixing this, instead of a shop?
post #3 of 5 Old 03-28-2017, 08:39 PM
Hello and welcome!
The filament in the bulb could have been damaged and only making intermittent contact.
Scorpi0 likes this.
post #4 of 5 Old 03-29-2017, 01:27 AM Thread Starter
When I got to my bike it was on the ground already and who hit it was gone and there was no cameras around that's the reason y I am fixing it but I will check the bulb and the high beam switch and socket thanks a lot for the advice keep everyone up dated thanks again
post #5 of 5 Old 03-29-2017, 07:03 AM
Something like this may be covered by your insurance under your comprehensive coverage, rather than an accident. That's typically a much lower deductible. Often $50 or so. It's worth asking your insurer. If you have crash bobbins that got scuffed up, a bar end with scratches, turn signals that are now scratched.... in addition to the wonky electrics, that could easily go into a few hundred at a shop to make it all right.
It's sort of like an act of God; you weren't there, the bike was not in motion, no one was operating it. If a tree fell on the bike, it's not treated the same as if you crashed it. Having someone back into your bike and knocking it over is similar. Same sort of thing as having a rock hit your windshield.... 99% of the time, that's not considered to be your fault.
Battery drainage problem philippe Mechanical and Technical 2 03-09-2014 08:47 AM
10 kawasaki zx6r clutch problem Loganvortex Motorcycle Talk 5 06-03-2013 05:23 PM
Battery Problem Rjg12 Mechanical and Technical 4 12-25-2012 05:52 PM
Dead High Beam zxMode Mechanical and Technical 16 05-13-2012 08:03 AM
dual low beam conversion???? Ziggyboo84 The ZX6R 6 02-18-2009 05:20 PM
