07 zx6r water pump rebuild - ZX6R Forum
  • 1 Post By Deanlollock
  • 1 Post By Scorpi0
post #1 of 8 Old 04-02-2017, 08:29 AM Thread Starter
Hello , so I have an oil leak behind the water pump housing, I know there's a gasket but I decide just to rebuild the whole water pump, but in the service Manual it says apply grease on the new o-ring. But what kind of grease? I have water proof grease by belray but I'm not sure if that's the right grease. Thanks
Deanlollock is offline
post #2 of 8 Old 04-02-2017, 08:41 AM
It sounds like that grease would work. I usually use marine grease on the bike.
post #3 of 8 Old 04-02-2017, 09:36 AM Thread Starter
Thank you I checked out the marine and the belray is not a silicone grease and it didn't say it was safe on rubber gaskets unlike the marine grease.
post #4 of 8 Old 04-02-2017, 10:32 AM
Find out what is recommended in the shop manual, and use that. If the specific procedure doesn't call out something unique, it'll be listed in the general requirements at the beginning of the manual....
post #5 of 8 Old 04-02-2017, 11:50 AM Thread Starter
The sealant they want me to use is $80 im better off just to take it to the dealer then
post #6 of 8 Old 04-02-2017, 01:18 PM
Grease for the bearing should be different from the housing sealant, I should think...
Ask riverszzr. He has many years of experience with motorcycle repair...... I'd trust his work far more than a dealership.
post #7 of 8 Old 04-02-2017, 04:45 PM
The grease is probably just used to help it seat without tearing. Just use whatever.
post #8 of 8 Old 04-02-2017, 08:16 PM
Sealant is different than grease. If it is actually a sealant you need, then look at Yamabond (Kawabond is stupid expensive). Yamabond is the same stuff, but it's around $10 a tube instead of $80.
09 zx6r fuel pump problems Fastjojoe New Users 1 06-18-2015 09:21 AM
05 ZX6R -Installed new fuel pump, now bike won't start Ridgedawg88 Mechanical and Technical 39 03-21-2015 07:57 PM
2003 2004 ZX6R Water Pump jacob92icu Mechanical and Technical 6 02-16-2015 07:30 PM
06 zx6r Water shooting off the exhaust dnukeg88 Mechanical and Technical 11 04-06-2013 08:46 AM
Water Pump Help 007 Mechanical and Technical 9 12-04-2012 08:24 PM
