Need help bad Electrical problem - ZX6R Forum
  • 1 Post By RJ2112
post #1 of 10 Old 04-09-2017, 01:04 PM Thread Starter
02ninja1979's Avatar
Turn key to on and nothing happens. It did it for a little while. But would wiggle key and it would work so Thought it was my ignition switch. Replaced it and still nothing happens. Sometimes when I put the key to on the gauges turn on but as soon I try to start, it turns off as if I had no key in. Check all fuses and even replaced 30 amp main fuse.
02ninja1979 is offline
post #2 of 10 Old 04-09-2017, 01:17 PM
Check the main ground cable
the prophet is offline
post #3 of 10 Old 04-09-2017, 01:37 PM Thread Starter
I checked and nothing. My multi-meter has a huge voltage drop once I turn the key to on. So something is going on. Battery has >12 v off then down to 1 v when turn to on.
post #4 of 10 Old 04-09-2017, 01:43 PM Thread Starter
So I unplugged tail lights and now it stays on but not enough juice to turn over. So I have to have a short somewhere.
post #5 of 10 Old 04-09-2017, 03:48 PM
Pull all the fuses except main. See if you still have voltage drop..
If so check out the schematics, that should greatly reduce the circuits that it could be.
post #6 of 10 Old 04-09-2017, 09:36 PM
Hello and welcome!
post #7 of 10 Old 04-10-2017, 02:09 AM
OP, how old is the battery?
Fully charged, it should read slightly more than 12 volts.
Get it load checked, before you tear into the bike too much....
Indy likes this.
post #8 of 10 Old 04-10-2017, 03:56 AM
Your battery is done. It should never drop to 1v even under a load.
PainfullySlo is online now
post #9 of 10 Old 04-10-2017, 06:54 AM
Further on batteries, they degrade over time and lose capacity to 'hold' charge... that's what it means when someone says a battery has become sulfated. the inert material that chemically bonds to the plates blocks the plates from accepting or releasing electrons. It's a byproduct of the sulfuric acid used in the electrolyte that bonds to the plates when electrolysis. Happens with every battery... each charge cycle is very slightly less capable than the one before.
this is why it is recommended to use distilled water if you ever need to replenish the electrolyte -- you will limit the amount of foreign matter in the water that will eventually bond to the plates and make them inert. Tap water has so many minerals in it you will make the battery die sooner than it would otherwise.
post #10 of 10 Old 04-10-2017, 07:21 AM
wildfire77's Avatar
I Ride: Track Preped 07 ZX6R
Electrical gremlins can mask and manifest themselves in various ways... Indy, PS, and RJ have the right idea.
Any electrical mods on the bike? (Its carbed, so no Fuel Controller, but just asking.)
Might have to go over wiring harness with multi-meter and inspect with a fine toothed comb... After a quick search/skimming the results, I've seen other posts about bad stator/rectifiers on your vintage of bike. Hope its not that bad.
Keep it on 2 wheels!
BIKES:
2002 Ninja EX250 sold (new 2002-2006)
2004 GSXR 750 sold (2008-2010)
2008 GSXR 1000 sold (new in 2010-2014)
2012 Aprilia Tuono RSV4 APRC sold (early 2014 - Fall 2015)
2007 Track Prepped Ninja ZX6R (Fall 2015 - Current)
wildfire77 is offline
2002 ZX6R Complete Rebuild - Relay problem videophotog New Users 4 09-12-2014 09:12 PM
Electrical problem please help Grasshopper Mechanical and Technical 16 04-01-2014 01:56 AM
Battery drainage problem philippe Mechanical and Technical 2 03-09-2014 08:47 AM
Electrical Problem Please help!!! PlasmaZX636 The ZX6R 11 03-01-2014 02:32 PM
electrical problem? kbergner409 The ZX6R 1 06-28-2012 01:03 PM
