Capitalcrew's track bike fiasco - Page 2 - ZX6R Forum
 13Likes
post #16 of 47 Old 04-14-2017, 11:55 AM Thread Starter
capitalcrew's Avatar
DID chain and sprockets are cumming.
Tires, oil change, valve check/adjustment and forks are the most important things left. Still leaning towards the battlax s21 tires unless someone says differently.
capitalcrew is online now
post #17 of 47 Old 04-14-2017, 12:42 PM
commiehunter's Avatar
I Ride: ZX6R 636
I really like the Michelin Pilot Power 2 that I have. It's supposedly dual compound so you get less wear in the center but more grippy on the edges. Eh? I like it. But I'm not tearing them up, either.
commiehunter is offline
post #18 of 47 Old 04-14-2017, 01:01 PM Thread Starter
The s21s are supposed to have 3 different compounds in the rear I guess. The tire just came out last year so maybe there isn't a ton of info yet, idk lol
post #19 of 47 Old 04-15-2017, 01:20 PM
Oil Filters: HiFlo is who I am using. They are the company that originally made the design with the welded nut for K&N (back when they were good). K&N has since farmed all their production out to China and now suck however HiFlo is still making the same high quality filters that originally made K&N famous and still have the convenience of the welded nut on the end of the filter.
You absolutely must balance motorcycle tires, especially ones which will be traveling at high speeds. The rear is not as critical as the front but it still needs to be done.
capitalcrew likes this.
PainfullySlo is offline
post #20 of 47 Old 04-15-2017, 03:10 PM Thread Starter
Thanks man.
I just checked the Valves, everything is within spec but most of the exhaust Valves are right on the limit. The intakes are all good. I plan on checking every season, is this something I should take the time and move them all to the middle of the spec or will they be good for 4-6 track days and maybe 1k Street miles as is?
post #21 of 47 Old 04-15-2017, 03:16 PM
I Ride: 2014 Kawasaki ZX-6R
@capitalcrew Here are a few options on oil filters with similar specs conveniently available at auto parts stores too.
Peter Verdone Designs - Motorcycle Oil Filters
K&N KN-303
Hiflofiltro HF-303
WIX 51358
NAPA 1358
FRAM PH6017A
I would probably stay away from the K&N and FRAM though, just because of some o ring failures.
Martillo y Mantequilla #99
post #22 of 47 Old 04-15-2017, 04:00 PM
Well I'm about to find out how bad it is without being balanced...just loaded up for a track day tomorrow (first time on track since September), and found the wheel weights from the front wheel on the ground next to the wheel. The guy who mounted the tire last apparently didn't put tape over it. The track I'm going to has a relatively fast straight (probably about 135-140 mph for a 600).
2013 CBR500R (race bike)
2009 ZX6R (race bike)
sbk1198 is online now
post #23 of 47 Old 04-15-2017, 04:24 PM Thread Starter
Lol, report back. Anyone ever tried the sand/beads truckers use to balance tires? I wonder how that would do.
I'm leaning towards leaving the valves as they are. I'm not going to put a ton of miles on the thing and they're still technically within spec, I can't imagine they'll move much by next spring and the bike runs and idles great.
post #24 of 47 Old 04-15-2017, 06:44 PM
Q3's.
Short of track tires they rock.
Addhoc likes this.
Indy is online now
post #25 of 47 Old 04-15-2017, 08:26 PM
Addhoc's Avatar
That's what I figured about the tires. Might buy or build a cheap balancer, this might be something I find myself doing often lol.
As for the throttle it isn't a complex assembly.. I don't know what could possible be going wrong, but I'll try it again when I get out of work. They do check throttles at this track, so it definitely needs to snap back properly.
Had a problem with a sticky throttle when I picked up my 07. The previous owner who was a turd had a P.O.S. aftermarket bling bling one on there. Replaced the tube with an R6 tube and new grips, adjusted the throttle cables and it solved everything. Just make sure the grips arnt sticking to your actual bars past the throttle tube and if they are cut a little off if the other end is up all the way
Addhoc is offline
post #26 of 47 Old 04-15-2017, 08:27 PM
Addhoc's Avatar
Originally Posted by Indy View Post
Q3's.
Q3+ per the tire thread
Addhoc is offline
post #27 of 47 Old 04-16-2017, 07:39 PM
Well I didn't feel a damn difference with the unbalanced wheel. Granted, this was the first time I ever rode this bike with a stock front wheel, and it's been like 6 months since I rode the bike anyway, so it's a bit hard to compare, but I really didn't feel anything odd, no chatter or anything like that. Seemed ok to me. Speeds were consistently in the 135-139 mph on the GPS, at the end of the straight.
Now at least I'll not to not be freaked out if it happens again in the future.
post #28 of 47 Old 04-16-2017, 08:14 PM Thread Starter
Interesting.
post #29 of 47 Old 04-18-2017, 12:09 PM Thread Starter
Well, no one has said different so I'm just gonna slap it back together for this year. Next year I'll drop the motor and adjust everything to the middle/upper end of the tolerance. Also gonna do the jumper mod while I'm at it.
Chain and sprockets came as did the replacement sprocket cover so I can get that taken care of when I do the tires in a week or two. I'm feeling good about getting the bike done in time, less good about being able to afford gear in that time as well though lol. Gloves, boots, and a suit by 5/13 plus the price of the track time. Cuttin it close. The cold weather lasting into this month really threw me off on timing.
post #30 of 47 Old 04-18-2017, 04:12 PM
K&N KN-303
Hiflofiltro HF-303
WIX 51358
NAPA 1358
FRAM PH6017A
Add Purolator PureONE PL14612 to the list.
Selling my bike :( 2008 KAWASAKI ZX 600 ZX6R P7F GREEN 2007 zx6rp7f Classifieds 2 04-07-2016 10:23 AM
New to me track bike (SV650) tong53 Racing 8 02-13-2015 01:34 PM
G2 Track Bike Progress Falcon Racing 4 07-05-2014 04:21 AM
Which bike would make the best track bike Gav179 Motorcycle Talk 14 02-22-2012 02:23 PM
