03/04 636 - Clutch problems - ZX6R Forum
  • 1 Post By novak
post #1 of 9 Old 04-16-2017, 12:48 PM Thread Starter
I Ride: 2003 636
1
Keishi is offline
post #2 of 9 Old 04-16-2017, 12:54 PM Thread Starter
I Ride: 2003 636
1
Keishi is offline
post #3 of 9 Old 04-16-2017, 12:58 PM
novak's Avatar
Yea that doesn't look normal. I installed an EBC clutch kit in my 03 and everything was tight in the basket, not loose like that. Also, your fibre plates actually don't look too bad, mine were burnt black and I was only noticing it slip in 4th and 5th gear at 13,000 rpms. You can check out some pics in this thread:
B1H Clutch Slipping
Keishi likes this.
novak is offline
post #4 of 9 Old 04-16-2017, 12:59 PM
novak's Avatar
Originally Posted by Keishi View Post
Noticed this too. How does this happen?
Is that the push rod that is broken?
novak is offline
post #5 of 9 Old 04-16-2017, 02:48 PM Thread Starter
I Ride: 2003 636
B1H Clutch Slipping
Thanks for confirming that. I wonder if anyone has seen this problem before and knows a fix for it. Fibers look good compared to what yours were but it definitely slips in 3rd around 10k rpms.
Keishi is offline
post #6 of 9 Old 04-16-2017, 02:51 PM Thread Starter
I Ride: 2003 636
1
Keishi is offline
post #7 of 9 Old 04-16-2017, 04:38 PM
Ya that pull rod is busted.
But its prolly not whats causing your shudder.
post #8 of 9 Old 04-16-2017, 04:48 PM Thread Starter
I Ride: 2003 636
1
Keishi is offline
post #9 of 9 Old 04-16-2017, 06:39 PM
Tighten down that center nut in the clutch basket. See if it makes a difference.
05 ninja 636 clutch too hard luis7190 Mechanical and Technical 8 01-10-2017 05:32 PM
03/04 636 owners, you have any problems with heel guards and boots? ConradM The ZX6R 2 08-09-2014 04:16 AM
2013 Ninja 636 starting problems nomorepain12 Mechanical and Technical 11 08-23-2013 05:46 AM
03/04 636 parts greg636 Classifieds 9 08-12-2011 09:54 AM
FS/WTB: 03/04 636 parts Abel Classifieds 3 07-16-2011 10:44 AM
