Leaking oil from drain hole under headers - ZX6R Forum
 13Likes
  • 2 Post By jenn
  • 2 Post By capitalcrew
  • 1 Post By WERA689
  • 1 Post By Twistee
  • 3 Post By Strider
  • 2 Post By Twistee
  • 1 Post By Gawernator
  • 1 Post By riverszzr
post #1 of 13 Old 04-18-2017, 09:17 AM Thread Starter
I have no idea what im doing. Help.
Does anyone know what could be causing oil to leak from that little drain hole under the headers? Only leaking from #1.
Already did a new head gasket and the spark plug tube seals.
Gawernator and capitalcrew like this.
jenn is offline
post #2 of 13 Old 04-18-2017, 12:34 PM
RoidRageFool's Avatar
I recently replaced my headers and don't remember any holes in that area, but maybe I wasn't looking. It doesn't appear that you have other holes under the ports so I wonder... Should that be there.
Racefit: Not for everybody.....
RoidRageFool is offline
post #3 of 13 Old 04-18-2017, 12:36 PM
LOL troll account is trolling
Gawernator and sbk1198 like this.
capitalcrew is offline
post #4 of 13 Old 04-18-2017, 12:54 PM
Gawernator's Avatar
uh.... broken engine block. RIP
Gawernator is offline
post #5 of 13 Old 04-18-2017, 01:32 PM
Site Admin
WERA689's Avatar
A little intentional(?) humor?
WERA689 is offline
post #6 of 13 Old 04-18-2017, 01:32 PM
Twistee's Avatar
I Ride: ZX6R G2 (99)
I was always told that if it can't be temporarily fixed with gaffe tape and a little Loctite, it's probably beyond repair.
Maybe if you bunch up a load of toilet paper and ram it in there?
Twistee is offline
post #7 of 13 Old 04-18-2017, 01:57 PM
Plug the hole with some bubble gum.
post #8 of 13 Old 04-18-2017, 01:59 PM Thread Starter
Thanks for all the help guys!
This is definitely a clean drilled hole and is supposed to be there. It's like a drain hole from the spark plugs.
jenn is offline
post #9 of 13 Old 04-18-2017, 02:49 PM
Twistee's Avatar
Make sure when you refit the headers to add a little copper slip to the studs. Wouldn't want those to seize up!
Twistee is offline
post #10 of 13 Old 04-18-2017, 03:47 PM
Hello and welcome!
A better question would be, "What is that huge hole in the front of the engine at the bottom of that picture!?" It looks like a big piece of the case is broken out.
Gawernator, sbk1198 and Twistee like this.
post #11 of 13 Old 04-18-2017, 04:29 PM
Twistee's Avatar
Originally Posted by Strider View Post
Hello and welcome!
You mean that isn't a crankcase breather port?!?!
Strider and Gawernator like this.
Twistee is offline
post #12 of 13 Old 04-18-2017, 10:10 PM
Gawernator's Avatar
I think you can fix it by starting up the motor and putting your hand into the frontal engine hole. Feel around.
Scorpi0 likes this.
post #13 of 13 Old 04-19-2017, 08:26 AM
I think I wouldn't worry about that hole and concetrate on the great big hole in the cases with the rusty rod poking through it.
But hey- you go ahead and sweat the little things and ignore the big ones.....
PSR Magnetic Oil Drain Bolt for their ZX6R? Vicious The ZX6R 25 07-02-2016 09:45 PM
Yikes! Blasting oil from air clean system oil receiver. RipRoarin Mechanical and Technical 22 07-19-2015 06:04 PM
Cracked my oil pan by torquing the drain screw... Jwf88 Mechanical and Technical 28 09-22-2014 09:12 PM
Leaking oil? ksteeeezy The ZX6R 13 07-13-2009 10:41 AM
