Strategies in track riding/road racing: Going faster by slowing things down - ZX6R Forum
 21Likes
  • 12 Post By PainfullySlo
  • 1 Post By Twistee
  • 2 Post By Sanctuary
  • 1 Post By Twistee
  • 1 Post By sbk1198
  • 1 Post By Twistee
  • 2 Post By harleystyles
  • 1 Post By RJ2112
post #1 of 9 Old 04-19-2017, 07:13 AM Thread Starter
It is no great mystery that we need to be in control in order to go fast on a motorcycle. Things like fear and doubt inhibit our ability to control things and so it stands to reason that if we can do something to prevent fear and doubt that we will have a better time in the saddle.
I can tell you with absolute certainty that every single time that I have turned a new PB (personal best...fastest lap) it has always been a surprise because I felt slow. I was calm, my actions were smooth and deliberate, and I did not feel rushed at all. In essence: I had no fear.
Now, even the best of us feel fear. I am sure everyone here knows what a survival reaction is; your bodies natural and instinctual response to fear. Because it is controlled by your subconscious we cannot change what we do but what we can control is when we start to feel fear. Here are some tips to help 'slow things down' which will help you gain confidence and feel more in control.
Reducing your sense of speed
Have you ever felt fear when driving your car on the highway under normal circumstances? I am betting no, even though you are likely traveling at ~70mph which is fairly quick. Why is this?
There are two main reasons: your sense of speed is reduced because the physical stimuli (touch, sound) of driving in a metal box is greatly reduced when compared to riding a motorcycle, and also because your vision is naturally farther ahead of you.
We can adjust these things on a motorcycle which will drastically help to reduce your sense of speed, and thus allow you to ride faster.
Let's address the physical stimuli first, and there are a myriad of ways that we can help ourselves feel more calm and reduce the sensation of speed.
  • Gear - wearing top notch protective gear helps to reduce our feeling of speed. If you can feel the air rushing by your body through a thin or poorly designed suit, it will make you feel more exposed. A helmet that is noisy or buffets in the wind will make you tense up.
  • Ear Plugs - The sound of rushing wind greatly improves your bodies perception of speed. Properly fitting ear plugs will reduce this while still allowing you to hear the important things that you need to hear. I am ALWAYS faster when I wear ear plugs.
  • Suspension - The main benefit of quality suspension is that it allows your bike to maintain a stable geometry while cornering but an added perk is that the bike feels more stable which reduces your sense of speed. A bike that is wallowing through corners can do horrible things to your confidence, even if the bike is no where near the limits of its traction.
  • Body Position - If your hands are lighter on the bars you will receive less vibration which also reduces your sense of speed.
As for vision, why does traveling at 70 in a car feel ok but may make us start to feel a bit nervous on a motorcycle? A street sign in the distance slowly approaches you and it feels perfectly natural. When riding a motorcycle we can see a lot more, including the ground which is much closer to us and moving by quite fast; this is where our perception of speed comes from. If you want to prove this out, try opening your car door (do this safely) and counting the dotted lines as they go past...suddenly 70mph doesn't feel so slow anymore.
We can counter this by keeping our vision high, essentially looking further into the distance rather than focusing on the road immediately ahead of you. It takes practice to do this but I promise that it is a worthwhile endeavor.
A general feeling of confidence will also help you to feel more calm and to push back the point where we start to feel panic. You can read more about that here: Strategies in track riding/road racing - Confidence
More to come as I get time.
RJ2112, Off Camber, jd41 and 9 others like this.
PainfullySlo is online now
post #2 of 9 Old 04-19-2017, 07:26 AM
Twistee's Avatar
I Ride: ZX6R G2 (99)
One of the errors I've encountered many times (and of which I was guilty when I first started) is trying to run before you can walk... or more appropriately, trying to go as fast as possible without increasing your capabilities and comfort to match the speed you're attempting .
Being comfortable with speed also comes with exposure to it. This, like exposure to other stimuli, will be far more comfortable over time.
Twistee is offline
post #3 of 9 Old 04-19-2017, 02:06 PM
As always, great post
capitalcrew is offline
post #4 of 9 Old 04-20-2017, 12:58 AM
Sanctuary's Avatar
I Ride: 2013 ZX6R, 2013 Triumph Street Triple, 2017 Triumph Street Triple RS (on order)
Funny. One of my coaches used exactly the same example! Lift the eyes. But the problem I find is if you take this to the extreme you tend to run off the track. The other technique I've been taught is taking "snap-shots". Supposedly our brains aren't good at registering changes in moving images, so the idea here is to look mid-distance, then further ahead, close, mid-distance and further ahead. If you keep darting your eyes you very quickly build up a picture without focusing on one spot that may be a hazard. Also using the wide-view (thanks CSS!) and trying to look for information outside of the immediate forward view helps slow things down too. Going to have to remember this shit when I'm back at the track in a days time. It's funny how easy it is to forget.
But yeah, great post. I never thought about how much proper gear or plugs helped me concentrate.
PainfullySlo and Twistee like this.
As you eat another's words
Malnourished, you starve.
Sanctuary is offline
post #5 of 9 Old 04-20-2017, 03:34 AM
Twistee's Avatar
Not only do earplugs help you concentrate by blocking out the shriek of wind noise (and thereby reducing the sense of speed), I also love them for giving me the chance to hear other things around me with greater clarity.
Is someone coming up behind me. Is that the right or left side?
Is that an unusual noise? Am I going to have to be 'The Fastest Clutch Hand in the West' because something's about to seize?
If you can increase your concentration to things that matter, the sensation of speed gets reduced significantly.
PainfullySlo likes this.
Twistee is offline
post #6 of 9 Old 04-20-2017, 05:38 AM
Man I really need to try to wear earplugs next time. I forgot last Sunday when I was at the track. And I even got a set of custom molded ones over the winter.
2013 CBR500R (race bike)
2009 ZX6R (race bike)
sbk1198 is offline
post #7 of 9 Old 04-20-2017, 05:55 AM
Twistee's Avatar
They're worth their weight in gold... which, admittedly, isn't a lot of weight at all.
I'd no more ride without earplugs than I would without a helmet or gloves.
Twistee is offline
post #8 of 9 Old 04-20-2017, 11:17 AM
I Ride: 09 ZX6R
I use the snap shot method as well. Although I have never heard it spoken of.
I try to look as far ahead as I can but I'm like you, too much to process. when I'm coming to the tip in point I try to look around to the clip point so I can make sure I'm in the right spot, then I'll glance back to the tip in point to verify, then look ahead to the clip point. As I'm tipping then I'll look for the exit of the turn to try to keep the best arc going then I'll glance back at the clip point to make sure I'm still headed for it, then look ahead to where I want to be on the track after the exit of the turn.
Sanctuary and PainfullySlo like this.
harleystyles is offline
post #9 of 9 Old 04-20-2017, 11:55 AM
Another very useful, informative thread. I knew there was a reason I kept hanging out here.....
Strategies in track riding/road racing: Front Grip Management/Bar input is bad m'kay? PainfullySlo The ZX6R 16 03-10-2017 05:16 PM
Strategies in track riding/road racing: GP shifting - the in's and out's PainfullySlo The ZX6R 15 02-25-2017 03:35 PM
St Louis (MO, IL, IN, KS area) people interested in getting on the track.. trackdayhero Racing 8 09-25-2012 10:46 AM
Kid runs on track while motorcycles are racing trev0006 Motorcycle Talk 7 09-18-2012 07:46 PM
