2013 ecu - ZX6R Forum
 6Likes
post #1 of 26 Old 05-01-2017, 02:37 PM Thread Starter
2013 ecu
My bike has had the cold start trouble from day 1,had it to the dealer many times and no fix.Had the ecu replaced during one of those visits and still won't cooperate.Just got it back Saturday from the dealer(since Oct) and low and behold its still not fixed after they changed the whole throttle body assy/injectors.So needles to say I'm tired of taking it there for nothing even though its still under warranty til july.I'm wondering If the ecu from a 2015 will fit the bike and run correctly as I'm at the point of buying a used one from ebay just to see if this is the trouble.I think the new ecu they put in has trouble also but they won't replace it again.So my question is if I buy the 2015 stock ecu can I put it in my bike and it will run correctly?
etuke is offline
post #2 of 26 Old 05-01-2017, 02:43 PM
I Ride: 2014 Kawasaki ZX-6R
Did you check the spark plugs and battery?
ZedExMuse likes this.
Martillo y Mantequilla #99
post #3 of 26 Old 05-01-2017, 03:47 PM
Do you have lemon laws in Canada? When I lived in New Jersey, I successfully filed a lemon law case against a car dealer that couldn't fix a leaking sun roof on a new car.
The law in Jersey, which I think is similar across the U.S., affords the dealer 3 attempts to fix the problem before a lemon law claim can be made.
It was super easy because there were Lemon Law Lawyers that take your case on the contingency that they will not charge you fees if they lose and they build their fees into the decision/settlement of your case, not taken from your awards. I took a $3 grand settlement for the issue. Was very minimal paperwork. Just was a lot of waiting. Basically got $3 grand off a new car for a problem I eventually got fixed. But an issue like yours, you can elect for a vehicle replacement.
Worth looking into.
Other advice would be to try another Kawasaki dealer.
Or contact Kawasaki directly. You'd be surprised at their customer service. I'm sure Kawasaki has field reps that bounce between dealers. They might send somebody out to consult. It's coming out of their pocket anyway. This happened with another one of my vehicles that was having an Air Bag issue. I got an actual specialized Tech with my car brand to come out and fix the issue.
ZedExMuse and Gawernator like this.
RedAndBlack is offline
post #4 of 26 Old 05-01-2017, 06:20 PM Thread Starter
Bike has 1500kms on it and they said they did check them,battery is new.
etuke is offline
post #5 of 26 Old 05-01-2017, 08:45 PM
uKER's Avatar
I Ride: 2013 ZX-6R 636
Can you check the numbering on your ECU?
The ECU that has the second number ending in 8963 should fix your issue.
If it's an 8962 or prior it won't.
Straight lines show the bike.
Curves show the rider.
uKER is offline
post #6 of 26 Old 05-02-2017, 03:29 AM Thread Starter
Already did the check for the proper ecu number last year and mine has the 9863 ecu,think you may have you numbers mixed up.
etuke is offline
post #7 of 26 Old 05-02-2017, 08:27 AM Thread Starter
etuke is offline
post #8 of 26 Old 05-02-2017, 04:19 PM
uKER's Avatar
Nope, my numbers are fine.
I had mine swapped and had to supervise the numbering change myself after they swapped it twice for ECUs that didn't solve the issue.
uKER is offline
post #9 of 26 Old 05-02-2017, 05:18 PM Thread Starter
Hope I'm not violating rules here but this is the ECU I was looking at on ebay,number clearly show 9863
http://www.ebay.ca/itm/13-15-KAWASAK...-ECU-COMPUTER-
etuke is offline
post #10 of 26 Old 05-02-2017, 10:01 PM
uKER's Avatar
Oh, wait. I did have the two first digits mixed up.
My bad.
The important thing is that the last two are 63.
If they already are and you still have the issue, I'm afraid I can't help you.
uKER is offline
post #11 of 26 Old 05-02-2017, 10:31 PM
If it's under warranty have the dealer troubleshoot it and report back. If not I highly suggest changing the spark plugs. I'm just saying because I had issues with starting too but changing the plugs solved it. . Just personal experience, not anything solid here.
post #12 of 26 Old 05-02-2017, 10:53 PM
ZedExMuse's Avatar
No, no, no, no.... You check the battery and replace the spark plugs. Then you A) know the job was in fact done; & B) you know the job was done correctly. Don't take some chimp's word for it.
C8H10N4O2
ZedExMuse is offline
post #13 of 26 Old 05-03-2017, 03:34 AM Thread Starter
Went back to the dealer yesterday and showed the new service manager the video and he was kind of surprised.He went and talked to the mechanic(I could hear them)and he said he was stumped with the bike.My warranty is running out and they don't know how to fix it.He said he will send the video to kawi and see if they suggest anything.If there were another dealer around I would take it there but there isn't.I'm not the type to just live with this problem so I may have to sell this bike and get something else.I know the battery is new because they filled it with acid when I got it,as for the plugs I am just relaying what they said.Back to my original post as the question I asked never really got answered,will the 2015 ECU work in a 2013?
etuke is offline
post #14 of 26 Old 05-03-2017, 04:36 AM
Gawernator's Avatar
If they can't fix it under warranty they MUST get you a new bike.
http://www.gawerracing.com
Gawernator is online now
post #15 of 26 Old 05-04-2017, 07:48 AM
Fireman237's Avatar
Go to a different dealer. Mine had the same issue as all other 13s. Took it to dealer, the were able to immediately duplicate the issue and ordered a new ECU right then. Few days later, I was good to go with no trouble since then.
Sent from my SM-N920V using Tapatalk
Fireman237 is offline
2013 ZX-6r Flashed ECU Dyno garth285 The ZX6R 33 11-18-2016 04:39 PM
2013 ecu etuke The ZX6R 20 10-21-2016 07:44 AM
HELP 2013 Cold Start ECU questions quantumk Mechanical and Technical 1 04-20-2016 07:22 AM
2013 636 ECU Location? Pogimoto Mechanical and Technical 4 05-15-2015 03:47 AM
