07 zx6r stator - ZX6R Forum
post #1 of 3 Old 05-11-2017, 11:42 PM Thread Starter
07 zx6r stator
Hello, I would like to what makes a stator or a rectifier go bad? My bike has stock light and no add ons. And my bike just hit 19,000 miles and I've seen forums and videos of other bikes going out around those miles.
Deanlollock is offline
post #2 of 3 Old 05-12-2017, 01:41 AM
post #3 of 3 Old 05-12-2017, 07:51 AM
aodrn's Avatar
I Ride: 2007 ZX6R
I copied this
A stator is nothing more than a laminated iron core with copper wire wound around it. That being said there is very little that can fail on them. Typically what happens is the coating on the wire burns off causing a short to ground, when this happens the stator can no longer produce current.
Often what causes this is heat or overworking the stator. Trying to charge a battery that is bad will cause the stator to work much much harder producing amperage that the battery will take, the end result is once the amperage gets high enough the coating melts off the coils causing a short..
Corrosion takes a part in this as well, as the stator has to work harder to push current into the battery again working hard.
aodrn is offline
Parts compatibility list ! Stiggy Mechanical and Technical 156 06-20-2017 04:49 AM
09 zx6r Stator Issue marloncs86 The ZX6R 9 02-21-2014 11:10 AM
WTB a 2010 or 2011 stator and reg/rec for my zx6r marloncs86 Want to Buy 3 02-21-2014 08:50 AM
09 zx6r stator cap for sell anyone? JizzleBonez New Users 7 08-18-2012 07:02 PM
