2013+ exhaust servo cables? - ZX6R Forum
 4Likes
  • 2 Post By MrZ
  • 1 Post By MrZ
  • 1 Post By andananimal
post #1 of 8 Old 05-13-2017, 04:40 AM Thread Starter
Does the 2013 zx636 have butterfly valve thingy with servo cables somewhere on the exhaust?
andananimal is offline
post #2 of 8 Old 05-13-2017, 04:43 AM
KHansen89's Avatar
Yes it does! Butterfly valve should be rite before the muffler I believe and the servo motor is under the riders seat!
Sent from my SAMSUNG-SM-N920A using Tapatalk
KHansen89 is offline
post #3 of 8 Old 05-13-2017, 05:02 AM Thread Starter
Bugger. Is there a method to remove or disable it when i fit the link pipe and aftermarket slip on and remove the cat?
Thanks for the speedy reply btw!
post #4 of 8 Old 05-13-2017, 05:11 AM
KHansen89's Avatar
That I can't give a definitive answer unfortunately cause I bought mine with all of that removed already! I can't imagine it being to difficult though! I do believe someone has a servo delete for sale as well in here!
post #5 of 8 Old 05-13-2017, 07:33 AM
MrZ
MrZ's Avatar
I Ride: my sexy Julia
You will disconnect the cables when you remove your stock exhaust and then you have to completely disconnect them from the servo motor under the seat.
13+ owners claim that you won't have an FI light or anything if you do that. But you could also get a "servo eliminator" module and completely ditch that servo motor for decreased weight and more space under the seat...for stuff
andananimal and KHansen89 like this.
MrZ is offline
post #6 of 8 Old 05-13-2017, 08:11 AM Thread Starter
Thank you mate! very helpful and much appreciated
post #7 of 8 Old 05-13-2017, 08:32 AM
MrZ
MrZ's Avatar
Also, i forgot...you won't be removing the cat if you don't change headers...because it's build in there.
So, if you still want to remove it, you have to DIY drill it out etc...or use aftermarket headers, or a full exhaust.
andananimal likes this.
MrZ is offline
post #8 of 8 Old 05-13-2017, 09:19 AM Thread Starter
yes, going to try the DIY method! but need to save for a bazzaz and dyno tune before i do that
MrZ likes this.
2013 636 Exhaust Options PowerGroove The ZX6R 1208 05-23-2017 03:11 PM
Exhaust Removal 2013 636 ZX6R IvyLeague Mechanical and Technical 8 09-16-2014 01:44 PM
2013 zx6r 636 servo wheel removal chips Mechanical and Technical 0 08-24-2014 12:10 PM
ZX-6R 2013 Stock Exhaust dB level? lun471k Mechanical and Technical 18 01-23-2014 01:50 PM
exhaust servo eliminator joey08zx6r The ZX6R 5 12-18-2013 01:52 PM
