milled heads & cams - ZX6R Forum
post #1 of 15 Old 07-06-2009, 08:39 AM Thread Starter
milled heads & cams
just like the title says im painting my bike and the motor is out of it so my question is ( my bike is a zx636 04 )
if i were to mill down the heads how much would i need to do and what size gasket would i need also port and polish them could i also use 05-06 head with there cam and valves ??
what cams will i need to install as well i see some of these people are putting cams in bike from 05-06 636 right
how much horsepower would i see out of this comb and what else would i need
thanks need all the info i can get thansk to eveyone who post
wheelies247 is offline
post #2 of 15 Old 07-06-2009, 08:44 AM Thread Starter
if anyone has these parts for sale or know someone let me know
thanks
bump
bump
post #3 of 15 Old 07-06-2009, 08:59 AM
zx racer's Avatar
I Ride: 04 ZX-636
you want to use the 05-06 zx6rr cams & springs, there the kawi kit cams they sell for the 03-04 models
zx racer is offline
post #4 of 15 Old 07-06-2009, 09:29 AM Thread Starter
ok thanks
could i use the o6 head and valve too
post #5 of 15 Old 07-06-2009, 09:41 AM Thread Starter
bump for more horsepower
post #6 of 15 Old 07-06-2009, 10:36 AM
ZoomSplat's Avatar
I'm not sure about the head swap, but I'll comment on your machining question:
If you're taking your heads to a machine shop to have them "decked" then you need to find out from them how much they took off, and then get a head gasket that is that same measurement over the stock thickness. If they take .020" off, then you need to get a gasket that is .020" thicker than the stock head gasket. You need to keep the distance between the crank and the cams the same, otherwise you'll run into valve timing issues because the tensioner won't be able to take up the extra slack later on down the road as the timing chain wears.
ZoomSplat is offline
post #7 of 15 Old 07-06-2009, 01:55 PM Thread Starter
thanks
post #8 of 15 Old 07-06-2009, 03:28 PM
caker_chris's Avatar
I Ride: 2006 Kawasaki ZX636R
instead of shaving the head, just get a thinner head gasket, but be preparred to have to get higher octane fuel, if it starts knocking.
Yoshimura RS-5 Slip-On
K&N Air Filter
Afam Sprockets (-1 front)
D.I.D. X-Ring Racing Chain
Vortex Frame Sliders
Galfer Braider Lines
EBC HH Sintered Brake Pads
Dr. FX fender eliminator
Clear Alternatives Integrated Tail & Flush Signals
caker_chris is offline
post #9 of 15 Old 07-06-2009, 07:27 PM
ZoomSplat's Avatar
it WILL start knocking. you're changing your compression ratio, so you'll get a little more power, but the problems that come along with aren't worth it.
post #10 of 15 Old 07-07-2009, 05:54 AM Thread Starter
about how much hp would i see if i shaved it thinner gasket and 03-04 zx6rr cams
im thinking around 20-25 hp with a good map and bolt ons
post #11 of 15 Old 07-07-2009, 05:17 PM
not nessarilly, depending on how much it changes, in most places in the states i noticed, the octane rating on super or premium gas is atleast 94 and the bike stock only needs 90 so it might still be good on premium fuel without an octane booster or race gas
but it is a risk you have to be willing to take, best thing to do if you are serious about increasing the compression ratio is to contact kawasaki and find out from them what octane you would need.
K&N Air Filter
post #12 of 15 Old 07-07-2009, 09:02 PM
ZoomSplat's Avatar
The highest I've seen around here is 91, but that's the people's republic of california and they're afraid to let people have any fun. I forget what it was back east but I think they had 93 at most stations.
I had a hot rod magazine a while ago that had a big long article about bumping up compression through various methods like stroke and thinner head gaskets and domed pistons; they had a formula to figure out what octane you'd need to run...I ran the numbers and it said that my Tacoma would knock at about 5 lbs of boost when running on 91, so I got in the truck and tested it out, and it was pretty accurate. I don't remember the formula to figure out compression ratio vs octane, and have since misplaced that magazine, but I'm sure someone could find it with a bit of googling.
post #13 of 15 Old 07-07-2009, 09:04 PM
yeah maybe about 5, 10whp pushing it
selfinfliction is offline
post #14 of 15 Old 07-08-2009, 07:46 AM
zx racer's Avatar
I Ride: 04 ZX-636
i would say around 10rwhp with a good tuner
zx racer is offline
post #15 of 15 Old 07-08-2009, 08:25 AM
TheVictor's Avatar
I Ride: 2007 ZX-6R
Yeah I hated that when I was in CA.... I'm in VA and we get the good ol 93 everywere ...... With that being said I would gladly trade that extra 2 oct for the weather and damn near every other asspect of SoCal.
Vic
STAND for something or you will FALL for anything.
TheVictor is offline
03 04 zx6r race cams
03-04 zx6rr head compared 05-06 head
04 zx6rr head same as 06 zx6rr
05 zx6r thin head gasket
2002 zx6r after market cam
2002 zx6r head gasket
636 thinner head gasket
cam timing 05 636 milled head
is 04 636 kawi pistons the same as 05 636 pistons
zx6rr cams
zx6rr race cams
aftermarket cams ninja z28 The ZX6R 16 05-03-2012 04:52 AM
My bike sounds like it has 240 cams aww sheet Mechanical and Technical 18 09-12-2011 07:56 PM
Heads up.... zx6chris The ZX6R 8 05-06-2011 09:06 AM
Race cams for 2002 zx6r 2002zx6r Racing 2 09-04-2009 06:25 PM
05/06 cams in 03/04 bike rattyzx6 The ZX6R 6 07-10-2009 01:38 AM
