Clutch Questions - ZX6R Forum
post #1 of 5 Old 05-14-2007, 06:19 PM Thread Starter
slow50's Avatar
I Ride: 06 zx6r
Clutch Questions
My clutch feels like it's slipping during hard shifts and *caugh caugh* wheelies. I know the 06 has a slipper clutch, is there anything different with the installation? Also, does anyone know if there is an aftermarket clutch kit available for these bikes?
Good news: My IQ test came back negative!!
start quote "they say sports cars are the extension of a man's penis.. i am guessing extended swing arms are simular for motorcycles.." end quote
slow50 is offline
post #2 of 5 Old 05-15-2007, 06:22 AM
BikePilot's Avatar
I Ride: TL1000S
While I'm not an expert on the ZX, I'm reasonably sure the slipper shouldn't affect anything while under power or general servicing, but referencing the manual couldn't hurt. Check cable and actuator adjustment (if applicable) or bleed if its hydro for starters. Then pull the clutch cover off and mic the plates, chances are they are fine and the springs are sacked or something along those lines. Also, is it possible your getting wheelspin? Generally, if a clutch is going to slip, it will do it while in the meat of the power in a high gear....
good luck
TL1000S and a bunch of dirty bikes
BikePilot is offline
post #3 of 5 Old 05-15-2007, 06:33 AM
SQDBIKE Admin
crashtd's Avatar
I Ride: 2004 R1 & 2009 Streetfighter
check the slack on your cables and lube maybe?
asphalt & rubber - tlzone - ninja6zone - rsvzone - tuonozone - postwhore - haiku-to-go
Support Ninja6Zone: SUBSCRIBE!!!
Ninja6Zone Forums Staff - Resident Tortfeasor
crashtd is offline
post #4 of 5 Old 05-16-2007, 06:23 AM Thread Starter
slow50's Avatar
I Ride: 06 zx6r
I checked the tension on the cable, it was a little off but I adjusted it back in so now that's good. I get wheelspin a lot and this is totally different. I know it's the clutch getting worn because I am rough on it.
slow50 is offline
post #5 of 5 Old 05-16-2007, 08:12 AM
BikePilot's Avatar
I Ride: TL1000S
well then the thing to do is pull the clutch cover off and measure the thickness of the plates and length of the springs
Clutch plates can generally take a lot of abuse though so its worth checking before you drop the cash for them. Could be something simple like springs etc.
good luck
2008 Zx6r Clutch Issues alfieferenzo Mechanical and Technical 2 01-18-2013 08:18 PM
my new (used) '05 636, got a few questions... ZX666R The ZX6R 25 10-13-2012 06:11 AM
2007ZX6R - Clutch Lever anderszx6r Mechanical and Technical 3 09-26-2011 11:13 PM
The Frayed Clutch Cable....Two Questions Armadillo The ZX6R 4 12-13-2009 08:22 AM
