2006 zx6r - common issues?
23K views 13 replies 11 participants last post by  BrandonZX6r
#1 ·
I'm entertaining the thought of buying a zx6r from a local guy.
What are some common issues/problems that I should check for before I purchase?
Thanks,
darrin
#4 ·
:rant Hi Dude! so far I am enjoying my ZX6R-06 and no minor complaint about the bike. My personal opinion in buying a second hand bike try to check the following:
1. fairings - check inside the fairings whether repaired and repainted because there is a possibility that the felled down.
2. Check first a bike with the same age and model particular all stock parts, all original paint then compare to the unit you are buying.
I am not so sure if there is a thread serving as reminders in buying a used bike. Basically since 2006 model is a very young model and knowing the performance of Kawi - I think you will not encounter problems or perhaps only minor. NOT UNLESS, there is really hidden defects of the unit you are buying. Try to ask the help of an expert mechanic to inspect the bike before having final decision. Hope this helps!!! Go for Kawi Bro!!!:):):)
#9 ·
I just bought a 06 636 about 3 months ago. I LOVE THE BIKE! Very fun and we'll balanced. But I think my ecu is failing. I have misfires at very light throttle, runs good with more throttle until I hit 11,000 rpm then it's like someone hit a kill switch for a split second. And now it's starting to run VERY RICH like burns your eyes if u r behind it. Both the map sensors read the same values with a vaccum pump applied to them, the throttle sensor has 5v supplies and ground and the output voltage is with in the normal range according to the service manual.
Any new ideas would b very helpful I need it running better asap....
I hate my car lol
